Local Spots with Slicemaster and CW Skimmer work on 40meters but not 20meters Cw Any ideas
mikeatthebeach .
Need help Seem Local Spots from CW Skimmer work on 40meters but not 20meters Been that way for a long Time Not sure why Slicemaster does not work On 20meters CW but works on 40meters With my Flex6600M Mike WB6DJI
To clarify this problem On 20 meters I see calls in CW Skimmer But not on Flex6600M Spectrum Scope With CW Skimmer I do see Local Spots from CW Skimmer appear On my Flex6600M on 40 meters but not on 20 meters CW as local spots the Flex6600M screen0
Double check to be sure that you have spots turned on in SSDR when you load your 20m profile. Also double check the settings in CWS when you're on 20m. For SM to send spots to SSDR I believe it needs to open CWS. If all that's good we'll dig deeper.
What settings in CWS Slicemaster must be To send Spots to Flex6600M On 40meters it all automatically done But when I try 20meters no Spots from CW Skimmer on the FlexRadio 6600M Spots are Enabled on Flex6600M For Spots to Show up on 6600M Must be something in Slicemaster That changes when going from 40meters To 20meters I use Slicemaster to bring up CW Skimmer automatically when I am in CW mode On the Flex6600M and start Slicemaster Mike0
40 meters SliceMaster works 20meters SliceMaster does not work0
Mike,
Are you sure it's a 20m/40m issue, not a Slice A/Slice B issue? Try reversing the bands on your slices and watch where the problem goes.
The only thing I can think of that might be getting in your way is the setting in CW Skimmer's Network tab called "Do not send callsigns without CQ". It's possible that you have this set on your 40m slice but not on your 20m slice. But last I checked, Slice Master adjusts this setting for you when it launches CW Skimmer.
--Don
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
- 456 Remote Operation (SmartLink)
