4K DIGU Slice but TX Suppressed above 2.6K??
Dwayne_AB6A
Working with a WSJT-X and a DIGU Slice opened up to 4K. I find that Transmit is suppressed above around 2.6K? Setting XMIT frequency at the upper ends of the slice and MOX is enabled but AMP shows no signal from radio. As I move the XMIT frequency back down below 2.6K I get a few watts before it jumps to full power from the radio.
Will using "Fake It" in WSJT-X solve the problem for you?
Two possible causes. Your TX bandwidth is to narrow. Or you are not running in Fake it/Rig mode in WSJT.
Change TX bandwidth in SSDR.(watch TX bandwidth on 60m)
Change to fake it in wsjt under File, settings Radio(not for 60m)
You have your transmit bandwidth set too narrow. It is on the Transmit Control panel, a pair of text boxes with up/down arrows at either end. Set the "High Cut" to 4kHz.
Awesome! I changed settings in WSJT-X to rig control, but I was not aware of the TX band settings... Under PHNE Settings correct in 3.1.8??0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
