.5 sec. TX audio delay in Monitor mod.
WA7NRX
My Maestro, controlling a 6300 has worked fine for a year, but now there is a .5 sec. TX audio delay in Monitor mode. Makes monitoring your own TX audio impossible Why is this happening?
Yes I see this too on both the 6700 and 6600 running SmartSDR 3.1.8 directly I don't remember 2.49 doing this and haven't checked over SmartLink.
I've tried several computers and all are the same, If you watch the waterfall and listen to the Audio it is weird to watch and listen with the Audio Latency being .5 sec slower then the Panadapter.
Bret
WX7Y
Yes, I didn't mention that in my post, but mine is the same. I always enjoy using monitor, but with the delay, there is no way. Now I have to fire up my 7800 to listen. Thanks for your input.
Fred
wa7nrx0 -
I ran the same issue up the pole a month or so ago. Was told it is a problem that the software people are, reportedly, working on. Haven't heard anything so far. Maybe a fix will be in the next software? In the interim, the monitor stays off...besides bands are horrible out here so it's only CW/FT#, hi hi. Aloha, AH6FC Bill0
Thanks for your input Bill. If you hear of a fix, let me know, and I'll do the same for you.
wa7nrx Fred
I finally figured it out. I had switched from direct control to control through my WIFY.
WA7NRX
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 68 SmartSDR+
- 181 SmartSDR for Maestro and M models
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 30 Aurora
- 232 FLEX-8000 Signature Series
- 930 Maestro
- 908 Genius Products
- 328 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 447 Remote Operation (SmartLink)
- 769 Peripherals & Station Integration
- 988 Third-Party Software
