DDutil with SPE 1K-FA
Joel Lobão
Joel Lobão Member ✭✭
edited February 2020 in Third-Party Software
Hi, I'm trying to use DDutil to change the SPE band remotely but i think i'm doing something wrong. When i initiate all sistem, DDutil read the QRG and change the AMP banda tio, but then, when i change the band on the SSDR nothing happens in DDutil or in SPE. This are my configuration. Thanks in advanceimageimageimageimage
  • Clay N9IO
    Clay N9IO Member ✭✭✭
    edited November 2019
    GM Joel.
    Just laying in bed reading and saw your post .
    I just set my 2K up recently this way and what I see your only change would be to be
    Under Passive Listener check Follow Radio.
    I'll confirm after I get to the radio.
    Everyone still sleeping here.
    I'm just reading the mail.
  • Steve - K5FR
    Steve - K5FR Member ✭✭
    All users that have upgraded to the new Flex SSDR versions >= 2.5.1 & 3.0.27 need to upgrade DDUtil to version 4.0.1.9 to be compatible with the new Flex releases.
    Flex SSDR v3 users: DDUtil is compatible for a single client only (SSDR-Windows). It does not support multi-clients yet. I’m working on a multi-client version but, it isn’t ready yet.
    73, Steve K5FR
  • Clay N9IO
    Thank you Steve,
    I had heard talk of a version 4 but did not see it offered on the web site.
    Will give it a go, but curious if you have a sheet on the improvements?
    Clay N9IO
  • Clay N9IO
    @Joel,
    Did the Passive Listener checkbox work for you?
    Clay N9IO
  • Joel Lobão
    edited December 2019
    Hi Clay, i tried with and without follow radio checked. About V4 o can't find it either. I tried with "check for updates" in the software but tell me that the DDutil server is offline.
  • Jeff Eli
    Jeff Eli Member ✭✭
    I clicked the link he provided in his comment. Downloaded with no issues.
