Smart Link log on screen postage stamp size
Steve Blankinship AG4SO
The Smart Link log in window on my Maestro is the size of a large postage stamp and can not read much less type in it, the rest of the windows are normal. Using Smart SDR 2.2.8 any suggestion on how to enlarge it?
I haven't gone down to the shack to double check, but I think what I have done when that happens is just use my fingers on the touch screen to expand it. The screen response doing that is a bit unpredictable, but I have always been able to get it big enough to see. Put your thumb and index finger together, press in the middle of the postage stamp, then expand the space between your thumb and finger. I usually have had to mess with it a bit to get it big enough.0
Getting there that enlarges the log in GUI however the pop up window it is in does not enlarge. I can move it around by holding the upper right edge a few seconds them moving with finger but not enlarge. I tried the 2 finger trick and holding the individual corners no joy.0
I don't remember exactly what I did. I just remember it was cantankerous. Maybe try double tapping on it before trying to expand it?
Nope the double tap then trying to expand did not work either . It sure is a picky touch screen1
Steve, I'm glad I'm not the only that had to get out the magnifying glass to read it
I year ago and no response or solution??
Has this been fixed.. I'm still using SmartDSR v2.49..
This just happened to me on a new computer..
SmartLink did not automatically connect. A window popped up and in the middle was a a postage stamp size box. With a magnetizing glass I was able to see it was a log on box. and was able to log in but this is not a satisfactory situation.
This laptop has a high resolution screen 3840 x 2160 with the recommended scaling of 250%, on Windows 10. The everything else with SmartSDr scales fine. The problem is with this log in box for SmartLink which is a tiny little box in the middle of a larger box. This box is not programmed to respect proper scaling. (The outline of the larger box would have make it the right size if the log in box was to fill it.)
Ken - VE5KC
Yeah this is a nuisance and you would think this is a pretty easy fix.1
I started a new message noting this as a problem. Maybe we can get some attention and get this annoying problem fixed.
Please post your comments to the new topic.
73.. Ken - VE5KC
I believe this is a recorded defect, I reported same to Tim in May this year.
This issue has been logged as defect number: 7478
Steve
Thanks Steve.. It is problem enough with good vision but for old eyes it's next to impossible to log in. I was showing my son how remote operation worked. With out his much younger eyes I wouldn't have known what was happening! It can't be that difficult to fix, maybe some reminders will help move it up the list. 73.. Ken - VE5KC0
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
