WATERFALL COLOR
Richard Zalewski
After yesterday's fiasco with the 6600M not starting I finally got it going. What I notice now is that when changing to a band initially the waterfall is mostly great. After a bit it starts going through different shadesof blue until it is the way I had it for months.
Sorry that should be mostly GREEN0
Sounds like it's set on "Auto" in the display tab. That's pretty much normal on mine - has always worked that way and I like to have it set the gain automatically. You could turn Auto off and manually set it, but then you might need to reset for each band (?) I've never used it that way so can't say for sure.
Tnx Duane. It certainly had something to do with the display settings. How they got changed is beyond me. I turned auto off and adjusted each band but will play with leaving auto on again and see what happens.0
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
