DXEngineering Time Variable Sequencer
ND8L
Need help with DXE-TVSU-1B. Has anyone installed one of these units with a 6600M? I'm specifically concerned about using generating CW via N1MM WinKey.
I purchased the TVSU-1B to protect the front end of the 6600M and the preamplifier in a Wellbrook receiving loop antenna.
Any help would be appreciated.
Thanks and 73,
Ray - ND8L
Thanks and 73,
Ray - ND8L
Are you sure you need the TVSU-1B? The 6600M has four relays it can switch at transmit time with independent delay times plus an additional TX Delay to control when transmitting begins. You should be able to do what you are trying to do with the TVSU-1B with at most just an external relay and a power source unless I'm missing something.1
That is what do with my RX antennas.
Gayle K0FLY
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 94 Aurora
- 988 Maestro
- 963 Genius Products
- 353 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
