DXEngineering Time Variable Sequencer
ND8L
Need help with DXE-TVSU-1B. Has anyone installed one of these units with a 6600M? I'm specifically concerned about using generating CW via N1MM WinKey.
I purchased the TVSU-1B to protect the front end of the 6600M and the preamplifier in a Wellbrook receiving loop antenna.
Any help would be appreciated.
Thanks and 73,
Ray - ND8L
Thanks and 73,
Ray - ND8L
Are you sure you need the TVSU-1B? The 6600M has four relays it can switch at transmit time with independent delay times plus an additional TX Delay to control when transmitting begins. You should be able to do what you are trying to do with the TVSU-1B with at most just an external relay and a power source unless I'm missing something.1
That is what do with my RX antennas.
Gayle K0FLY
- 650 The Flea Market
- 153 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
