2 Radios separate networks one SmartLink Account
Peter Schudel
Hi folks, we are two operators in different state. Each one runs a FLEX 6300 with V3. We now want to use our system cross wise. I figured out that we must use only one common SmartLink Account. The question is about the registration of the machines. Do we both have to unregister the HW and then one has to log into the common SmartLink and register his radio. Then log out and pass the account over to the collegue for doing the same procedure for his HW?
Will it be possible to select a specific machine in the chooser...connect it and work all modes with DAX and CAT properly? Or do we have to take care of some specials?
Thanks for giving us hints!
Peter HB9ASV
Peter HB9ASV
Define "cross wise"
73 Chris0 -
Station A wants to fully utilize B's station and B wants to utilize A's station at the same time.0 -
OK, but that is nothing special. Yes it works. OP A and OP B work remote.
But i think that is not the question from Peter0 -
As I read the question, it is about how to set up the smartlink accounts. You should be able to use the existing smartlink accounts, or set up additional ones if you don't want to share passwords.
>> or set up additional ones if you don't want to share passwords. <<
How that work? More then one account possible?
Thanks for your answer. My problem is solved so far. We set up a common account and shared the password. A little bit tricky was to unregister our radios from our previous accounts and then to register them again in the new common one. Now we see our radios in the chooser list, and we can connect vice versa. I hope everything works now as usual even when switching from one radio to the other. Using both simultanously needs two PCs I assume. 73, Peter
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
