PSDR V2.8.0134 and Windows 10 with FLEX 1500 with always short dropouts
Anton Bonnert
Flex 1500 with dropouts at RX and TX.
PSDR V 2.8 and Windows 10
During operation I have short interruptions at RX and TX. During operation, practically one syllable is "swallowed". The duration of the dropouts is different and varies from about 50 ms to 250 ms. The repetition time is also different and lies between 4 - 15 seconds. I extended the RAM memory from 4 to 8 GB but without success. I am grateful for any hint.
The following is in use here:
DELL Latitude E6400, with INTEL Core 2 Duo CPU P8700 2,5 Ghz, 8 GB RAM
Windows 10 Pro, 64 BIT Version 1903
Power SDR V2.8.0.134 (by KE9NS)
CPU load 30-40%
Translated with www.DeepL.com/Translator
CPU load 30-40%
Running Windows dropouts point to a DPC latency problem.
1. Run process hacker 2 to look at all the programs and services eating CPU
https://processhacker.sourceforge.io/downloads.php
2. Run a latency checker https://www.thesycon.de/eng/latency_check.shtml
3. Terminate/**** all processes you don't need
4. Look at you USB connection. Too many USB devices can also cause dropouts.
5. Look at your virtual audio cables. Are they set to 48000 Hz?
As audio and video processing are prone to dropouts caused by DPC latency, it is
always a good idea to look at pages like this one:
https://help.ableton.com/hc/en-us/articles/209071469-Optimizing-Windows-for-Audio
I still use a Flex 3000 for fieldday and EMCOMM and a Flex 1500 to try new ideas.
The notebook I use is a Toughbook CF52 running Windows 7. I got DPC latency down
to almost none. Now I'm trying to switch to Windows 10. Wish me luck :-)
73, Alex - DH2ID
Danke Alex,
das sind sehr interessante Infos. Werde Deine Hinweise Schritt für Schritt durcharbeiten. Wird zwar eine Weile dauern, aber ich melde mich um das Ergebnis mitzuteilen. Bin zuversichtlich, dass das alles klappt.
Hoffe, dass bei Dir und der Umstellung auf Windows 10 alles rund läuft.
nochmals vielen Dank und vy73, Tony DJ8RQ1 -
Hallo Anton, Du kannst Dich auch jederzeit per email an mich wenden.
Die Adresse steht in QRZ.com. Mir gefällt Deine Drake-Line!
Vy 73, Alex - DH2ID0
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
