power genius XL on SDR Version 1.12.1.31
Ian1
Ian1 Member ✭✭
Gentlemen
My Power Genius showed up yesterday and I haven't unboxed it yet. Had to make new LAN connections due to repairs on the QTH.
Here is the question will the Power Genius work with SDR Version 1.12.1.31 or do I need to just update to version 3?
Asking because I can't remote into my Florida station due to manual antenna disconnect. Due to lighting issues.
Ian
  • Mack
    Mack Member ✭✭✭
    edited November 2019
    Ian,
    Yes, it will work with SSDR  version 1.12. Post any questions here and I'll help.
    Mack
    W4AX
    Alpha Team
  • Rick N4RZ
    Rick N4RZ Member ✭✭✭
    edited February 2020
    Yes, the amp will work with SmartSDR version 1 like it will with any make of radio.  However, I don't believe you will be able to control or monitor the amp from within the software.   I think those features were added in version 2.
  • Ian1
    Ian1 Member ✭✭
    edited May 2020
    Thanks Guy's
    I was able to replace the LAN connections around the house today I will get the AMP running
    Ian
