Streamdeck file request
Rich McCabe
Member ✭✭✭
I have a stream deck out for delivery today. Would be interested in getting a jump start on seeing how it works. Anyone that has a config file they are willing to share I would appreciate it. You can email me via email listed at https://www.qrz.com/db/KD0ZV
Thanks and 73,
Rich
Thanks and 73,
Rich
A comprehensive configuration file comes with FRStack. It is about the best starting point possible. The Stream Deck is easily extensible, so you can add your own folder trees based on Mark's sample file.
Thanks Craig, is there info in how this works somewhere? I did not see anything in the FRstack documentation on how do do any of this.
Once you get the Stream Deck and install the software, there are two files in the FRStack3 program folder under C:Program Files (x86) that you double-click on to run:
com.mkcmsoftware.restcall.streamDeckPlugin and
FRStack3 Rest.streamDeckProfile
These will set up the Stream Deck for FRStack3. After this, it will all become relatively obvious in the Stream Deck program.
Thanks again Craig. Software was already installed. Doing as you said did change Stream Deck so I will wait for the hardware.
Rich
kd0zv
Yes, the FRStack Help file has a pretty easy to understand instructions. Got the StreamDeck doing some pretty neat things for the 6600M (as well as doing things for my Anan and Elecraft KPA500 amp by sending serial commands).
Well I have already figured out I want the XL instead. Interesting program. Is there documentation somewhere on all the commands, etc that can be used with Flex? Want to set up screens more for tasks than grouped radio functions.
The FRStack Help file has a pretty comprehensive document on all the commands available.0
Yes, that is what I need. I clicked help and looked like a duplicate of the webpage. I did not scroll far enough.
Is there anyway to cancel a CWX send besides using a hotkey for escape? This works when SmartSDR has focus but otherwise doesn't. And is there a better place to discuss this products use with FRStack than here?
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
