Slow internet after connecting FLEX-6400 via computer network bridge
In the past I have successfully used a network bridge under Windows 7 to share a Wi-FI internet connection on a computer (running SSDR) with an Ethernet port on the same computer connected to a FLEX-6300 radio.
I have recently upgraded to a new notebook (HP Probook 450 G6 with Windows 1809) for SSDR and a FLEX-6400 running v2.6.1. With this new configuration I can still use the network bridge functionality to connect the radio to the internet, but it is having a serious and unacceptable impact on internet performance. Internet connectivity is intermittent and the upload and download speeds are no more than 10% of the speeds achieved when the wireless network adapter is removed from the bridge. I have installed the latest drivers for the wireless and Ethernet adapters but this made no difference.
Have others encountered this problem? Any thoughts on the possible cause and/or solution?
Thanks in advance, Brian VK3MI
Can you describe how you connected the Flex to the WiFi bridge and to the Internet Gateway? Is that Gateway a Cable modem or VDSL modem?0
Hi Arvind
The gateway is a service provider router connected to a cable modem. The notebook wireless adapter connects to the router via WiFi. I'm using the network bridge function within Windows 10 to bridge the wireless adapter to an Ethernet port which is connected to the FLEX-6400.
I've used the exactly the same configuration previously, except I was running an older notebook with Windows 7. There was no evidence of the network bridge having any impact on internet speed in this earlier implementation.
73, Brian VK3MI0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
