On screen keyboard is horrible
Beric Dunn
Flex-6400 Software 3.1.8
Just got the Maestro, and tried to enter my wifi password. Very difficult entering the password without phantom key clicks. For instance, press "e" and "ez" is entered. Seems like a bad screen? But running the radio, the touch screen works as it should.
Eventually managed to get it to take my password, but not looking forward to having to do it again.
Yes, Beric, it is a bit of a pain. I had the same problem when I first received my Maestro back in 2016. The good news is that I have never had to enter the password since then.
As I understand it, the reason it occurs is because the password has to be entered during the boot up of the imbedded Dell Tablet, which is beyond Flex’s control.
My only suggestion, in case you do ever need to enter it again, is to use an inexpensive ($5) iPad touch pen.
Hi Winston,
Thanks for the reply.
It is frustrating as this is one of the first impressions with this device, and out of the box it does not seem like the experience you would expect from a device that costs more than an HF rig.
Also, not sure if this is just the boot up for the Dell, because I get similar behavior when I am trying to change my call-sign.
I'll have to try getting a touch pen and see if that helps.
-Beric
i have an issue with the keyboard never loading right 50% of the time, it just closes it as fast as it opens it, did the touch pen help?0
Swipe in the text box, instead of press, it will load the keyboard every time with a swipe. the issue is it gets confused on what kind of keyboard to load, number or text, the swipe will always force the text keyboard to load then you have to switch to the number keyboard if you want to put in numbers
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
