N1MM CWX
Sherman Banks
The Maestro works well using CWX with N1MM+. What it does not currently do is the keyer speed selected via the Maestro knob does not follow the speed selected in N1MM+. The result is when I change speeds in N1MM+ I have to make sure it is matched on the Maestro for manual keying using my paddle. Is there a way to have them match? It would be real slick if I could change the CW speed via the Maestro knob and have it change in N1MM+.
Doesn’t work that way with any radio that I’m aware of....if you use an external keying device, like winkey, that accepts your paddle input, that’s the only way I know of....but....I usually set the paddles a bit slower anyway, for fills, etc....0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
