6300 Transverter output problem
Robert N2AIO
I am using version 3.1.8. I have no output from the transverter jack. I made sure to setup the settings for Max output 4 dbm. RF Freq 144 IF Freq 28. I did a test using another radio for receive on 10 meters with the coax jumper from the other radio next to the BNC jack and heard nothing and no signal. I did the opposite transmitting from the other radio and the Flex received fine. Also the receive is fine with the transverter hooked up on 2 meters. If anyone knows what the problem could be and has a fix please let me know. Thanks
Robert, What specific model transverter are you you using? I have some ideas but need a bit more info. 73, Mack W4AX Alpha Team0
UT5JCW with the attenuator board bypassed
Robert, I’m assuming you bought the board built and tested. I would try a radio reset follow this procedure: https://helpdesk.flexradio.com/hc/en-us/articles/360020078612-How-to-Completely-Reset-a-FLEX-6000 Let me know if that fixes it. Please also include a screenshot of your transverter settings. Mack0
I did the radio reset and it didn't work
You may need to select the transverter for transmit. Also ensure a PTT line (TX1, etc) is connected and active.0 -
That was it George! I guess I was confused because the PTT line was keying the transverter. Thank you
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 95 Aurora
- 988 Maestro
- 963 Genius Products
- 353 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
