Maestro + Flex 6500 - update to V4.60 NO MIC OUTPUT ?
N4ZAX - PAT
Using a Maestro + Flex 6500 on V 2.49 - All is Well, Updated to V2.60, No Audio output from Mic FHM-2, bought a new Mic from flex, they sent me FHM-3, check every setting that has to do with the MIC and Profiles, just NO Audio RF Power. On CW I can get Full 100 Watts no problem. Any ideas on how to fix this Glitch?
Pat,
Does the either mic give you indication on the level meter ? Have your tried the factory reset procedure ( export your configurations first so you can import it later. ) ?
AL, K0VM
Depress the Mic/Speed knob. Verify that DAX is "NOT" selected. This has bit me several times.
73 Gayle K0FLY.
That was the answer Gayle, Thanks for the TIP !0
- 650 The Flea Market
- 153 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
