My 6700 having a seizure
Pat N6PAT
A while back I posted about my 6700 going crazy. Well tonight it did it again and I got it on video.
I had 4 pans and slices open for 80,40,30 and 20 meters. I then closed down SSDR v2.6.1 and reopened a while later. The slice for 80 was still present but the other slices that I had open were gone but the three empty pans were still open and going wild as if there was intense activity even though there is no slice present. The first pan with a slice present was working normally.
I had to shut everything down and do a factory reset for it to work properly again.
I should note that this bizarre behavior never happened once in the 2 years I've owned the radio prior to the rig being sent in for repair. Now it has happened twice since it was returned to me.
I suppose some folks will say all is well and the radio is just doing what it's supposed to do.
I would appreciate it if someone from FRS would offer an explanation as to what would be causing this.
Enjoy the show!
Enjoy the show!
Pat,
Since the Pan Adapters are still there with the frequency spread at the bottom the actual receive frequency that you are calling a slice may be off the screen to the left. Happens to me all the time. The problem is we can't tell because you have the left side menu pulled out and covering the arrow that would show that. Granted it should have been where you left it but in my mind you do have a "slice" because there is a frequency range at the bottom of each pan adapter. But the frequency it's on is off the side.
If you want a reply from flex you would need to open a help desk ticket. You'll probably just get replies like mine here. I really don't think after the fact anyone will be able to figure it out. It would have been better to leave it as it was and then post your video. I for one would have told you to close the left menu and see if it showed the VFO off to the left.
Harold
Harold,
That's a good suggestion but the slices were not there. The "off screen" indicator was not present in the three pans. Even if the slices were present they would have been out of band for some reason and that still does not explain the bizarre activity in the three pans while the first pan appears normal.0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
https://www.youtube.com/watch?v=BBD1cXag4cY
