Phantom Signal?
Andrew Sommers
I’m getting what must be a phantom signal just below whatever frequency I operate. It’s on every band at the same distance below my operating frequency and it’s a noisemaker. Radio is a 5000a with the V/U board. Any ideas?
If possible try running the programs from a laptop or another PC that is not using anything associated with your current PC and see if the problem is still there.
I fixed it. I had the interpolating noise blanker set too tight and it was causing this image.
3 -
I am having the same problem with my 5000a. I am new to this whole world of SDR, what setting did you change to sort out this issue?
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
