Flex 5000a CW with DM780 question
Paul Krog
Hi all, Just wondering if any out in the Flex 5000 world are now or in the past running the 5000 doing CW using HRD DM780? Thanks Paul KR5OG
Yes you can, but radio is not in actual CW, but still in audio. (DigU mode). because you are making the CW note via DM780 , sending the audio via VAC to the radio to be transmitted.
Dudley
WA5QPZ
Thanks Dudley, I will give that setup a try, it makes sense. All my other modes work with that setup. Thanks again Paul KR5OG0
Dudley, I have tried your suggestion on the CW issue I was having and it does produce a good signal but DM-780 does not decode incoming signals when set to DIGU Any other suggestions that could help? Paul KR5OG0
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
