Install instructions for ERC Version 4 rotator controler
Chris Weir
I know it's a long shot. But I picked one up second hand and the DVD was lost. I called Vibroplex and they said they didn't have any copies and I would need to buy another to get the instructions. If anyone happens to have a copy they could rip a ISO of it would be great. I would like to test with this one before I go buy 4 more.
If I have to buy another. I will.
Thanks!
Thanks!
Did you check the web: https://www.schmidt-alba.de/eshop/shop_content.php?coID=14&language=en
That's the origin, and a German Ham and nice guy.
Vibro is only the US distributor
73 Chris1 -
Unfortunately it does not. I have that. but the DVD has where to tap the actual controller and as far as I can tell that is not available online. I was able to download the firmware and control software from there. That is a step in the right direction though!
Actually the instructions are available on his web site, this the USB version:
https://www.schmidt-alba.de/eshop/media/products/0516706001526531485.pdf
The other versions are available as well.
https://www.schmidt-alba.de/eshop/index.php?cPath=1_5
just select your model, click on "details" and the download for the docs is at the bottom of the page.
Here is the complete instruction for ERC v4, all there is https://www.schmidt-alba.de/eshop/media/products/0516706001526531485.pdf?MODsid=9635f25ea89434d1187f...
Craig,
Thanks the kit I have was assembled. I am looking for the documentation on integrating it with the controller itself. The PDF is for assembling the kit. The instruction on hooking it into the controller are on the DVD as I understand it.
I have the disc and doc's. What are you looking for exactly?
Chris,
I have the CD with the installations instructions, actually for an earlier model, but the installation should be the same. Can I email it to you?
Depending on what rotator you are trying to control you need the instructions for the rotor card. For example with my Yaesu G450 the rotor card interfaces between the ERC and rotator. rotor card instructions are here https://www.schmidt-alba.de/eshop/media/products/0511101001526531307.pdf
Craig or Mike. I need the instructions for the hy-gain/CDE controller.
Thanks!
chris@km4ktc.com
Looks like Mike got me over exactly what I needed! Thanks guys! What a great community!
Glad its what you wanted and glad I was able to help. Currently using it with a G-450A works great.0
Hi Guy's I know this is from 2019 but if anyone had the CD can you check on there and see if there is a USB driver for the ERC V4 or what ever version you have I just can not find the driver for it.
Rob
- 636 The Flea Market
- 144 SmartSDR+
- 431 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 46 Aurora
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
