Flex 5000a CW with DM780 question
Hi all, Just wondering if any out in the Flex 5000 world are now or in the past running the 5000 doing CW using HRD DM780? Thanks Paul KR5OG
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    edited March 2020
    Yes you can, but radio is not in actual CW, but still in audio. (DigU mode).  because you are making the CW note via DM780 , sending the audio via VAC to the radio to be transmitted.
    Dudley
    WA5QPZ
  • Paul Krog
    Paul Krog Member
    edited September 2019
    Thanks Dudley, I will give that setup a try, it makes sense. All my other modes work with that setup. Thanks again Paul KR5OG
  • Paul Krog
    Paul Krog Member
    edited October 2019
    Dudley, I have tried your suggestion on the CW issue I was having and it does produce a good signal but DM-780 does not decode incoming signals when set to DIGU Any other suggestions that could help? Paul KR5OG
