Flex 6400 keying an Alpha 76a
Jerry Harley
can I key directly? Alpha 76a says 26vdc 76ma.
This is a copy/paste directly from the 6x00 hardware manual:
Δ – The TX Relay outputs are designed to handle signaling levels of up to +40 VDC @ 140 mA maximum. Some amplifiers do not have circuits to prevent keying voltage transients and older amplifiers may exceed the maximum voltage level resulting in damage to the radio if directly connected. Verify the voltage/current on your external device before connecting to TX Relay 1-3. FlexRadio highly recommends the use of a use a buffer/isolator box between the radio and the external device as a best operating practice regardless of the keying voltage.
So, yes, you can key it directly if after looking at the keying pulse directly with an oscilloscope you determine there are no keying spikes from a relay coil field collapsing.
Mack
W4AX
Alpha Team0 -
I use an Ampkeyer from the Heathkit Shop to key my SB 220. Bryan make one now that will control 2 amps in case you have 2.
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
