Maestro audio disappears
James Madden
Initially the maestro audio is ok but sometimes it goes away. Why is that and is there a way to adjust the audio volume on the maestro? Thanks jim
Ps if i go back to sdr the audio is fine.0
Jim,
Which audio output(s) on the Maestro are you having problems with ? Internal spkr, external spkr, headset ?? Or are you having a problem the TX audio ?? I have not had any problem with my Maestro audio disappearing..
AL, K0VM
Jim, did you get this resolved? I was having audio coming out of my Maestro B headset when I pulled out the mini plug to try and listen over the Maestro speakers — I didn’t hear anything, but when I plugged my NRad W1 headset back in I no longer could get any audio that way either. I’m not muted. I checked my antenna receiver - that’s ok too. I have rebooted Maestro but I’m likely missing something obvious. I’ll check with you all here first before I submit a ticket for support. Thanks everyone.0
- 368 Community Topics
- 625 The Flea Market
- 8.1K Software
- 74 SmartSDR+
- 421 SmartSDR for Mac
- 270 SmartSDR for iOS
- 189 DAX
- 33 Aurora
- 238 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 913 Genius Products
- 331 Tuner Genius XL
- 122 Antenna Genius
- 293 Shack Infrastructure
- 449 Remote Operation (SmartLink)
- 773 Peripherals & Station Integration
- 991 Third-Party Software
