Issue #7620 deals with restoring values
Jim Shaffer
Jim Shaffer Member ✭✭
Issue #7620 deals with restoring certain values such as the keyer setting.  Any idea when this will be fixed?  I don't see it in the 2.6.0 or 3.1.7 change logs.
  • Eric-KE5DTO
    edited September 2019
    This is an acknowledged bug.  Unfortunately, I don't have a date for when it will be fixed at this time.
  • Tim K9WX
    Tim K9WX Member ✭✭✭
    edited May 2020
    Is the list of issues public?  I sometimes wonder if an issue I am having has been formally identified.  Being able to view the issue list would allow me to answer this question, but I have never been able to find it on the Community or on the Flex web site.
    Tim K9WX
  • Eric-KE5DTO
    No, the list isn't public.  We will do our best to answer questions about specific issues though.
  • Jim Shaffer
    edited November 2019
    As primarily a CW op, I'd really like to lobby for this one.
  • Lionel
    Lionel Member ✭✭✭
    What is #7620?  Also CW here but what am I missing here? It seems okay for me.
  • Eric-KE5DTO
    The title is: "CW Settings are not restored when importing Preferences"
  • Tim K9WX
    Tim K9WX Member ✭✭✭
    Eric can you provide a link to this?  Searching the Community for that specific title does not locate any posts with that title.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    This is one of the things that makes this forum a little un-helpful. The search function is worse than the one in youtube. So many results returned are not relevant to the search term. It could at least return results in chronological order
  • Eric-KE5DTO
    You're probably better off to search for #7620 here in the community (and I usually just use google with a search term like "site:community.flexradio.com #7620").
  • Jim Shaffer
    edited May 2020
    I notice that, with version 3.1.12, issue #7620 still isn't fixed.  For me, this effects the following values, breakinDelay (always 0), side tone gain (always 80), keyer (always iambicB), and keyer speed (always 30).
    Is this scheduled to be fixed soon?  It's been an issue for quite a while.
  • Eric-KE5DTO
    edited May 2020
    I wish I could give you a better estimate of when this will be fixed and I do understand your frustration.  Unfortunately, I can't comment on when we will have a version that addresses this, but I will make sure that your input here is noted.
