Keying an amplifier
Paul F6EXV
Hi all
My 6500 is no longer keying my Acom2000a.
Using SSDR version 2.5.1, and on the TXs setup in "Settings" 3radio setup", I do see the 3 TXs, but I see no button to activate them .
Is this normal, or am I missing something somewhere else.
Also, the version I have shows USA for region. I want to change it to France, but do not know where to fing the adequate file.
Thanks for help and 73
Paul F6EXV
Paul F6EXV
Paul,
the TX1-3 is configured under TX Band Settings...
The radio is controlled by a TURF file which tells what region you operating in. Not sure why this is corrupted, I would do a full reset to see if ti works. If not, contact Flex and they will send you a proper TURF file that will turn your radio to the correct region
/Lasse SM5GLC
Go to settings, TX Band Settings. Then enable the correct TX port for your amp.
Place a check mark in the boxes for the bands that your amp supports.
Contact your dealer or FlexRadio to get the correct TURF file.
Mack
W4AX
Alpha Team
Found it, many thanks !
I sent an email to the Help Desk, and await their reply with the turf file.
Thanks again +73
Paul F6EXV
- 651 The Flea Market
- 154 SmartSDR+
- 50 Aurora
- 964 Maestro
- 938 Genius Products
