Antenna Genius New Firmware Release v3.1.2
We are happy to announce the release of a new version of Antenna Genius software:
http://www.4o3a.com/…/ag_w…/AntennaGeniusDesktop_3.1.2_2.exe
Changelog:
Release 17-Sep-2019
App v3.1.2
Firmware v3.1.2
Firmware:
#027 Option to disable band checks is added (Enables use of inband station and diversity reception).
#026 Support for special OM for AB switches is added (4x32 stack is possible).
#025 Direct connection from AG to Flex is enabled (instead through application) for getting band data.
#024 Support for Flex 3.0 is improved.
#023 Stack stability is improved.
#022 New version of the TCP/IP stack used.
#021 Some unused features were removed.
Windows app:
#020 OM window "Always on top" functionality can now be turned off
#019 OM profile configuration for antenna 8 is fixed.
#018 Uptime will now count days correctly.
#017 Configuration will no longer be corrupted in case the antenna is named nothing (no characters).
Here's the 403A FB post:
https://www.facebook.com/4O3ASignature/posts/2222688068022567
John
K5OOP
When will documentation be available???0
The Antenna Genius is an accessory item that we distribute from 403A. As such, all documentation that is available will be found on their website: www.403a.com. You can also inquire with 403A on their FB page.
John
K5OOP
Nothing there... still waiting for the promised documentation for ver 3.08 soo won’t hold my breath waiting for this one hi hi0
How do u update the firmware? According to 4o3a, when u install the update it also updates the firmware. The app keeps sqwacking to update the firmware. Reverted to previus revision, alls OK.0
@Bob. you need to manually update the AG even though it says it updates automatically. Just browse to the location of the new downloaded file and hit update on the AG App.... Known issue
Thanks, that worked.0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
