Amplifier not keying with 6400M and AL80B.
Mick
Hi, I've got my amplifier connection coming out from TX1, but it will not key the amp. Its an Ameritron AL80B.
When I take the RCA end out and put it to ground it keys, so it's not the amp.
Everything in the Transmit menu is set to default.
Please post a screen shot of your transmit setting. Have you tried Tx2 or Tx3. 73, Mack W4AX Alpha Team0
Make sure the relay is active in the rig setup. If I recall, the TX1,2,3 relays are not active by default. If you’re sure you’ve got it enabled, check the RCA connector with an ohmmeter to confirm it’s closing. The relay is rated to 140 mA, and the Ameritron specs 100 mA, but I am not sure I’d trust MFJ with my Flex. An isolating interface box is a good idea when switching a relay coil, since voltage spikes could be present far in excess of normal values.1
Yes, I've tried all 3. Sorry about the upside down, don't know why it did that.
I have the ARB704 in line.
I see RCA TX1 Is set to Zero, Change it. Should be good then.
This is the screen I’d like to see. TX1 must have a check mark. https://images.app.goo.gl/ajBhJve67PBwESMX80
When Smart SDR is running go to upper left to settings. Then go to TX band settings.
Make sure the RCA TX1 is checked . I have a 6300 and using 2,51.
This is most likely your issue, Let us know. Good luck.0 -
It is all unchecked as pictured.0
TX1 must be checked. Mack W4AX1
Fixed it, Thank you so much.0
That was it.0
Done.
Great! Glad it’s working.1
Same happen to me with Ten Tec Titan 425 with 6400M0
I am having the same problem with my 6400M and an acom 1200s. I don't use the windows software just the radio.
Go to TX Band Settings from main menu and check TX1 for each band you want to use the amp on. Make sure RCA cable plugged into TX1 on radio.
Thank you. I don't recall ever having to do that before.
Stephen NG0G
Older versions of software had the ability to enable TX1 from the TX tab. New versions of the software have a new feature called TX Band Settings table where you can set the TX1, 2 , and 3 lines on, RF power per band, tune power and other settings.
- 634 The Flea Market
- 134 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 298 Shack Infrastructure
- 210 Networking
