Flex 6300 receiver is scanning
Raymond Graham
Raymond Graham Member
I messed up and improperly shut down a 6300 by turning off the PS first. Now slice A receiver is scanning and I can’t stop it. Any suggestions?
  • Dave Pease
    Dave Pease Member
    edited September 2019
    do a reset
  • Raymond Graham
    I reset to default settings. Still scanning.
  • David-N5PSM
    David-N5PSM Member ✭✭
    Un plug the flex-knob??
  • Ross - K9COX
    Ross - K9COX Member ✭✭
    Are you using a Yaesu mic with scanning buttons?
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    edited March 2020
    Yes,  remove the mic from the front panel,  see if the issue goes away .   Some times the reset helps odd issues or just removing the DC from the radio and restarting ..    Try removing the mic first.
    Dudley
    WA5QPZ
