HELP - FT8CALL setup
Al Reeves
Al Reeves Member ✭✭
Looking to try the new FT8CALL mode.  So far I have not been able to get it to work with my 6300.  The 6300 is setup and works well on FT8 using WSJT-X and JTAlert.  Does anyone have any detailed instructions to setup FT8CALL?
Al
W1JHU
  • WK2Y
    WK2Y Member ✭✭
    edited September 2018
    Are you on the right frequencies?  They are recently changed and there is a new version of FT8CALL that was just released.
    I have been using it successfully on a 6500 and the set up I use is the same as I have been using for JTDX and WSJT.  Under the Radio tab I have the following:
    Rig:  Kenwood TS-2000
    Serial port:  Com9  (yours may be different)Data bits: Eight
    Stop bits: One
    Handshake: None
    DTR: Nothing
    RDS: Nothing
    PTT Method: CAT
    Mode: None
    Split: None
    Under the Audio Tab I have
    Input: Dax Audio RX-3 (yours may be different
    Output: Dax Audio TX
    I can't guarantee this is the best way to configure things but it works for me.  I think I  found this set up for WSJT on a FLEX FAQ and it has worked for that, JTDX and now FT8CALL.
    Let me know if you need moredifferent info.
    73, Bob
    WK2Y'
  • Ed, K0KC
    Ed, K0KC Member ✭✭
    Al,
    I have been using FT8Call successfully for over a week. I believe that my settings were the same as for WSJT-X and JTDX but if  you want to discuss it over the phone, give me a number to call in a private email. I run a 6700. My email in QRZ.com is ok.
    Ed, K0KC
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    edited March 2020
    You did notice that the program only runs for 10 days and then has to be re-downloaded to try to keep everyone up to date to changes.    This is their way to handle changes while still in Beta mode.
    Dudley
    WA5QPZ
  • Lawrence Gray
    Lawrence Gray Member ✭✭
    Rig and Audio Settings are the same as FT8.  Works a treat.  Just had a nice Q with 9L1YXJ in Sierra Leone.  Nice to be able to send free text. I'm using a 6500.
  • Patrick
    Patrick Member ✭✭✭
    edited June 2020
    It has been 12 months, so here is a quick update. Name has changed toJS8Call and it is release version 1.1.0. ... I have been using it for a few days and is working well, minus my learning curve. Set up is the same as FT8, but you should use a different tcp port then FT8 if loaded. Still looking into set up of logging with Log4om.
