Flex 3000 trips switchmode psu but not analogue psu
Why does flex 3000 trip certain power supplies by just connecting dc cable.
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    edited March 2020
    Some power supplies do not have the negative connected to chassis ground, the 3000 has the negative side connected to chassis ground. 73, Dudley
  • Michael Holtham
    edited August 2019
    Hi Dudley, so I guess the switched mode psu that only trips with the 3000 has a floating output. BTW it is fine with all my other kit.
  • Dudley  WA5QPZ
    edited March 2020
    Does it trip when you power the 3000 on?
  • Michael Holtham
    edited August 2019
    Hi Dudley No it trips as soon as it is connected to the dc cable. Was thinking back emf from a relay but its before switching on. Radio works fine on the old manson psu so its no big problem, just curious. Will meter it up and try the switched mode again. I do appreciate your interest in my issue.
