Using 6400M with CWX
mlstutler
I am helping a friend with his 6400M and I was trying to set up CWSkimmer to use. I could not find any CWX on the 6400M so I loaded SmartSDR and it came right up but on slice A. The 6400M was on Slice A as well. I could not get it to switch to slice B. When pressing the tx/rx buttons on the 6400m they were disabled. Since it appears there is no direct CWX function on the radio, I am assuming I must use SmartSDR.
Any ideas why slice B was locked out? Thinking it has to be cockpit error but I could not get SmartSDR to use slice B no matter what I did.
thanks
thanks
Are they both connected at the same time? If so, multiflex set a slice A on each connected device. Since it's a 6400 only has 2 slices available, A on one device and A on the other device is all that is available.
I just did some testing just now with my Maestro / 6400. In order to get SmartSDR on slice B I have to bring up both slices on the Maestro, while having no slices on SmartSdr. Then if I disable Slice A on the Maestro can create Slice A on SmartSDR. Does this sound right?0
ah ok I did not even go down the multiflex road...0
Don't ask how I knew about this. The local computer and the Ipad work the same way. V3 is kinda odd in the way it handles these things.
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
