SmartCAT
Mark Erbaugh
Mark Erbaugh Member ✭✭
edited February 2020 in SmartSDR API
I’m working on my own GUI client using FlexAPI, but SmartCAT doesn’t recognize it? Do SmartCAT and SmartDAX only work with FRS GUI programs?
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    edited August 2019
    Your program is a GUI program if you set API.IsGUI = true; before you call radio connect.
    Once you do this and connect your program should be listed with other GUI Clients.
  • Mark Erbaugh
    Here's my startup code:
            public Main()
                InitializeComponent();
                WindowPlacement.SetPlacement(this.Handle, Properties.Settings.Default.WindowPlacement);
                API.IsGUI = true;
                API.ProgramName = "N8MEFlexWinForms1";
                AttachEventHandlers();
                API.Init();
    The computer name is QUAD. If SSDR Windows is running QUAD is in the dropdown list,
    but with my client it isn't. What am I missing?
  • James Whiteway
    edited August 2019
    Version 2.51 only allows a single GUI app to connect to the radio and display things like the panadapter and waterfall. You can run a non GUI app and a GUI app like SSDR together. That's the reason I upgraded to v3. James WD5GWY
  • Mark Erbaugh
    I'm only running one GUI app at a time. When my app is running, no other GUI apps are running.
    I think I know the answer, but I just want to confirm. Under version 3, if you have two GUI apps running, do changes made one GUI app affect the other. IOW, if I change band/frequency/mode on GUI A, does it change band/mode/frequency on GUI B? I was under the impression that the two clients were more like two separate radios.  What I started out doing was trying to improve on the panadapter / waterfall display while still using Smart SDR Windows (or the Maestro) to handle the rest of the settings.
    I now think that, even with Version 3, I would have to handle all the features in my client just to be able to display a different panadapter or waterfall.  If I'm wrong, the version 3 upgrade becomes more attractive.
  • Mark_W3II
    You missed one very important step or you have not included the code.
    Here is my guidance again.
    Find, locate, browse, etc to get the Radio object then radio.Connect();
    If you want help collaborating on your project, I would suggest you create a GitHub account, add your project then invite those who you want help from to the project.
  • Mark Erbaugh
    Mark, I didn’t show that part of my code, but I do connect to the radio.
  • Mark Erbaugh
    edited August 2019
    Mark,
    After a lot more testing, I reverted my 6700 to v2.4.9 and SmartCAT recognizes my GUI client. There must have been a change in the process with the conversion to v3.
    Under v2.4.9, SmartCAT connects to the radio as soon as I select it. Under v2.5.1, it won't connect to the radio until a GUI client is running. But it seems like merely setting IsGUI in the API isn't enough.
    I've  opened a help ticket on this issue. Hopefully, someone in the know from Flex will tell me what's missing.
  • Mark_W3II
    edited August 2019
    You are using the FlexAPI V3+  with 2.5.1 and 3.X right?
  • Mark Erbaugh
    Okay, it turns out that with FlexAPI v2.5.1, you must call the Radio object method, SetClientStationName. Once you do that, SmartCAT will find your GUI client.
  • Mark Erbaugh
    edited August 2019
    I'm using FlexAPI v2.5.1. My understanding is that it incorporates the changes needed to support the v3 common code.
