SmartCAT
Mark Erbaugh
I’m working on my own GUI client using FlexAPI, but SmartCAT doesn’t recognize it? Do SmartCAT and SmartDAX only work with FRS GUI programs?
Your program is a GUI program if you set API.IsGUI = true; before you call radio connect.
Once you do this and connect your program should be listed with other GUI Clients.0 -
Here's my startup code:
public Main()
InitializeComponent();WindowPlacement.SetPlacement(this.Handle, Properties.Settings.Default.WindowPlacement);
API.IsGUI = true;
The computer name is QUAD. If SSDR Windows is running QUAD is in the dropdown list,
API.ProgramName = "N8MEFlexWinForms1";
AttachEventHandlers();
API.Init();
but with my client it isn't. What am I missing?
Version 2.51 only allows a single GUI app to connect to the radio and display things like the panadapter and waterfall. You can run a non GUI app and a GUI app like SSDR together. That's the reason I upgraded to v3. James WD5GWY0
I'm only running one GUI app at a time. When my app is running, no other GUI apps are running.
I think I know the answer, but I just want to confirm. Under version 3, if you have two GUI apps running, do changes made one GUI app affect the other. IOW, if I change band/frequency/mode on GUI A, does it change band/mode/frequency on GUI B? I was under the impression that the two clients were more like two separate radios. What I started out doing was trying to improve on the panadapter / waterfall display while still using Smart SDR Windows (or the Maestro) to handle the rest of the settings.
I now think that, even with Version 3, I would have to handle all the features in my client just to be able to display a different panadapter or waterfall. If I'm wrong, the version 3 upgrade becomes more attractive.
You missed one very important step or you have not included the code.
Here is my guidance again.
Find, locate, browse, etc to get the Radio object then radio.Connect();
If you want help collaborating on your project, I would suggest you create a GitHub account, add your project then invite those who you want help from to the project.
730 -
Mark, I didn’t show that part of my code, but I do connect to the radio.0
Mark,
After a lot more testing, I reverted my 6700 to v2.4.9 and SmartCAT recognizes my GUI client. There must have been a change in the process with the conversion to v3.
Under v2.4.9, SmartCAT connects to the radio as soon as I select it. Under v2.5.1, it won't connect to the radio until a GUI client is running. But it seems like merely setting IsGUI in the API isn't enough.
I've opened a help ticket on this issue. Hopefully, someone in the know from Flex will tell me what's missing.
You are using the FlexAPI V3+ with 2.5.1 and 3.X right?
Okay, it turns out that with FlexAPI v2.5.1, you must call the Radio object method, SetClientStationName. Once you do that, SmartCAT will find your GUI client.0
I'm using FlexAPI v2.5.1. My understanding is that it incorporates the changes needed to support the v3 common code.0
- 354 Community Topics
- 619 The Flea Market
- 8K Software
- 4 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 220 FLEX-8000 Signature Series
- 927 Maestro
- 898 Genius Products
- 457 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 979 Third-Party Software
