SDA 100 Quit again.
Andy W3LI
Andy W3LI Member ✭✭
Turned the SDA 100 OFF and went to bed. In the morning booted everything up but NO AUTOTRACK. It worked for about 3 weeks since the last problem.
  • Mack
    Mack Member ✭✭✭
    edited August 2019
    Andy,
    Have you removed power from the SDA 100 (pulled the DC plug on the back of the radio)? Have you checked all your connections are fully making contact? Has ANYTHING else changed? Is AutoTrack turned on and the LED illuminated on the front of the SDA 100?
    Mack
    W4AX
    Alpha Team
  • KL4QG
    KL4QG Member ✭✭
    edited May 2020
    Hack don’t worry about it life to short worry about things that Don’t work
