Flex-3000 died. No pilot light. Fan ok. Mechanical click sounds every second (Relay?)
H Layer
Alas, my 2011 Flex-3000 just crashed. Symptoms: Pilot light no longer lights although Astron-20 PS shows normal current drain. Fan runs normally. Mechanical clicking noise every second. Software does not load. Any ideas? Thanks, Hal KK6HY.
That means the rig is not fully completing its power up routine. I would try reloading its firmware from the control app..
Check for 5 volts. Sounds like the 5 volt regulator is not working or input voltage way too low. Dudley0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
