Flex-3000 died. No pilot light. Fan ok. Mechanical click sounds every second (Relay?)
H Layer
Alas, my 2011 Flex-3000 just crashed. Symptoms: Pilot light no longer lights although Astron-20 PS shows normal current drain. Fan runs normally. Mechanical clicking noise every second. Software does not load. Any ideas? Thanks, Hal KK6HY.
That means the rig is not fully completing its power up routine. I would try reloading its firmware from the control app..
Check for 5 volts. Sounds like the 5 volt regulator is not working or input voltage way too low. Dudley0
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
