JBL control 2P speakers
I have one here, give me a call .
Gary @905-937-24770 -
You can get all you need at Amazon.1
Thanks0
Amazon has everything0
I have the same set of JBL speakers Joe, those powered speakers sure do help and were a step up from the Bose Companion II speakers which were demoted for field day use. Gotta say this, to each his own but why on earth would you put speakers or for that matter, anything on top of your radio worth thousands of dollars. Over time it will leave marks bring the resale of the radio down and your hum maybe caused by the close proximity of the speakers to the radio's power supply, certainly more susceptible to RF.
If you separate your speakers more you will enjoy the binaural audio and diversity much better. See pictures below, I also wrapped the audio cable several turns on a ferrite to eliminate RF that I had. Just a suggestion.
Joe,
A cable like that one shown above worked for me, NO hum. However, if you are running the speakers with no input (not hooked to anything) you WILL hear a hum. Hope that cable works for you as it does here.
Don, WB5HAK
I would recommend these if you want a much higher quality cable with better connectors and better shielding.
They are more expensive but it’s worth it in my opinion.
https://www.sweetwater.com/store/detail/IPMB2R10--pro-co-ipmb2r-10-10-foot
John do u need use both RCA connectors I just ordered sweet water0
One thing I find they don’t amp sound much in my headset at all I was disappointed in that I have cheap Pair powered speaker amp sound. very loud in headsets when plug in0
I spread speakers out sound better i just have wait for sweetwater cables now0
They do sound nice I have play with -2 + 2 bass /T and normal little switch on back0
I’m going give my RadioSport headsets rest now need
Find of best of best Studio Type mic-Guy make this mic said its best mic in world for Flex 6400M anyone use this
INRAD M-650 microphone I like holding mic or in hanging stand cage I have not Desk stand0 -
Just connect the 2 RCA connectors to the back of the JBL's UN-Ballanced RCA connectors, Hook up the supplied extension speaker cable and that’s it.
Start with the HF (hi frequency or treble) Adjust switch at 0dB.0 -
Yes because your flexradio has a stereo output witch is great if you want to put one slice on the Left and another on the Right. Cool Stuff!
Connect you headphones to the "Phones" output on the back of the radio. There is a separate headphone level is SmartSDR.
I don’t have SmartSDR as of yet our computer not hooked up yet my friends 12 old boy going program the radio and computer - we just got internet first time we ever have computer and WhyFI Internet0
There is almost an unlimited amount of mic choices that will work great with a FlexRadio from a cheep eBay mic to a Hi dollar studio mic. The mic you choose will depend a few factors such as your budget, the type of audio you are looking for and your voice.
My suggestion is to start with the Stock hand mic that comes with the radio you will be surprised at how good you can make that mic sound on the air.
I have had lots Mic
From Heil. To cheap I’m not using cheap mic or supplied hand mic
Up $250 for mic I pay I paid lots for ant / 1500 watt amp I hate cheap things -0 -
The secret with these speakers is to use an 'ungrounded" power input! Simply use a three prong to two prong power adapter and don't connect the ground which is the source of a nasty ground hum.
Mitch - AE2A
So how u do that cut off something on plug to remove the ground0
Go to Home Depot or ACE hardware for the "adapter". I never mentioned cutting off anything.
It costs about dollar or less!
Mitch - AE2A
Ok I just don’t connect that brass thing on plug with hole in it -thanks I ask a question to get correct answer thanks0
Ok no stores for 500 miles I’ll Order plug on line0
It's working for me!
Mitch - AE2A
Cool0
Audio Isolation transformers do a great job of eliminating ground loop hum. Bought mine on amazon and used them at every device that were causing hum. Also had ground loop problem with my vhf/uhf gear when hooked up to the cars audio system. Transformer removed all gum. Works great!0
Good point Pat, I forgot about that. I use Pyle PLGI35T got three of them when they about $6 each. One for each radio, going into an used DJ mixer so I can use the JBL speakers on any radio. Totally eliminated all ground loop hum.
https://www.amazon.ca/PLGI35T-8-Inch-Stereo-Ground-Isolator/dp/B004HJ35F2/ref=sr_1_3?keywords=pyle+a...
Hum coming only from speaker that plugs into master powered speaker the powered speaker has no Hum waiting on 2 prong plug from ebay we have no stores here -0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 178 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
