2nd ptt on flex 6300 to key transverter
edited December 2019 in FLEX-6000 Signature Series
Adding a 4metre transverter to the 6300, all good but the ptt.
I am using a usb cable set to bit type, it is recognised by the 6300, set it up as per the download but as soon as I connect ptt line to transverter it puts it in tx
Any suggestions welcome
TIA
Welcome!
  • Member ✭✭
    edited August 2019
    Do you have the Polarity in the BIT setup screen set fo Active HIgh?  This is the correct choice.
    Also do you have the PTT set to OFF (correct).  Jim K4JAF
  • Member
    edited August 2019
    Yes I have Jim...
  • Member ✭✭
    edited August 2019
    Sorry, perhaps someone else will jump in here.   Jim
  • Member
    edited August 2019
    Thanks Jim, I think Ive tried all combinations. but I am of course open to all suggestions
  • Member
    edited August 2019
    it looks like pin11 from HD15F is the relay for ptt.  you might  check for a short on this pin or to make sure that this pin is not grounded all the time.
  • Member
    edited August 2019
    Hi Dave this is using usb from the flex not the accessory port
