2nd ptt on flex 6300 to key transverter
peter
Adding a 4metre transverter to the 6300, all good but the ptt.
I am using a usb cable set to bit type, it is recognised by the 6300, set it up as per the download but as soon as I connect ptt line to transverter it puts it in tx
Any suggestions welcome
TIA
TIA
Do you have the Polarity in the BIT setup screen set fo Active HIgh? This is the correct choice.
Also do you have the PTT set to OFF (correct). Jim K4JAF0 -
Yes I have Jim...
Sorry, perhaps someone else will jump in here. Jim0
Thanks Jim, I think Ive tried all combinations. but I am of course open to all suggestions0
it looks like pin11 from HD15F is the relay for ptt. you might check for a short on this pin or to make sure that this pin is not grounded all the time.0
Hi Dave this is using usb from the flex not the accessory port0
- 650 The Flea Market
- 153 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
