Ciro Mazzoni Loop and Flex Panadapter 6600.
Matthew Charnecki
Wondering how it has been working or if anyone is using. Live in a Restricted sub, but have a Vertical (not enough ground radials due to space and structures. Saw the magnetic loop but worried it may be two narrow for the Panadapter to work- I apologize if has been answered- found question asked a few years back but never saw public answer.
I have an MFJ loop, good for 30m and up. I found it not terribly useful on receive with a wide panadapter on any of the 30/20/15m bands, especially useless to see what was on 20m. I have a separate broad (i.e. all) band receive antenna I use all the time - it’s a “loop on ground”, 60 feet of insulated wire around the base of a big tree, dug just under the sod, connected with a beverage transformer. Works a treat, albeit a bit low on signal strength, but that is compensated for by the really low noise. Totally stealth for the receive antenna :-) Usual tx antenna is in the attic, a ~160 ft loop, again, keeps the HOA hounds at bay.0
I have been seriously considering the MIDI LOOP by Ciro Mazzoni.
Looks good from people's comments.
https://www.eham.net/reviews/detail/12952
http://www.ciromazzoni.com/loop-midi
Here are the Specs:
http://docs.wixstatic.com/ugd/1aa222_185d0c04919743469c50caf82488bc1f.pdf
That is one monster loop!0
If you want a Wide-Band receive only antenna the Beverage antenna is a very good performer.
You do need some decent space for this antenna.
https://en.wikipedia.org/wiki/Beverage_antenna
It's also quite expensive as well
- 361 Community Topics
- 622 The Flea Market
- 8.1K Software
- 47 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 289 Shack Infrastructure
- 203 Networking
- 141 Contesting
- 985 Third-Party Software
