PanadapterList
Mark Erbaugh
I'm trying to learn the SSDR API (v 2.5.1). The Radio object has a property PanadapterList which is documented as a list of panadapters in this radio instance. I'm running SSDR regardless of how many panadapters are displayed, PanadapterList is always empty. PanadaptersRemaining seems to have the correct value (i.e. on my 6700, with 8 panadapters available, PanadaptersRemaining shows 6)
If I remember right, from the release notes Slice 8 is Broken on the 6700 but could be wrong in either case look in the release note for these new versions in 2.5.1 ans 3.0.27
73's
Bret
I looked in the release notes and didn’t see any mention of PA 8 problems. Also, my problem is with all panadapters. I’ve never tried my software with all 8.0
Mark, there is a thread in the API section here, where Eric mentions that those two do not currently, return a value as the version of the api at that time did not keep a count of panadapters in use or available. The last time I played with that, I just queried the radio model and kept count of how many panadapters I had opened or closed. That may well have changed by now. But, v2.x broke my last working version of my program and things ( life and work) have kept me from fixing and updating my program to work with v3.x of the API. Hope you find a better solution. James WD5GWY0
Mark, here's a link to Eric's statement I mentioned. https://community.flexradio.com/flexradio/topics/using-flexlib-how-many-pan-adapters-are-available0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
