RCA TX does not operate
Martin
On my 6300, if I select RCA TX 1, it does not work. No keying on my accesories (relay)
I have tested every posible combination and nothing.
No other programs running on pc.
It is like this since new version with different settings for each band (v2.5.1)
I plug my amp relay box in this jack on the back of my 6300 and it works fine w/3.0.27 ssdr
And i set up the controls for each band accordingly
It does work for me this way. even when I run remote.
As Jim already commented, this menu is a NEW item under "Settings" and it is called "TX Band settings..." on the 6700, 6500 and 6600 (not sure on the 6300) you click ON the "RCA TX1" if your running Amp keying on that port on the bands you want to use the Amp/relay on.
Bret
SOLVED.
I do not know how,but after various resets, now it works
Thanks everybody
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
