Turn off 6600M display?
Wayne W5GIE
Should I try to turn down the display on my 6600M? I normally operate the radio from a desktop in another room. I have a huge amount of RFI from a neighbor's solar panels, so the display is quite bright even with the display gain at about 30.
Even better would be a way to pretty much switch off the display when operating remotely.
Is this something I should worry about with the display?
Wayne W5GIE
Wayne W5GIE
I asked this early on with my 6600M but Flex claimed that it was not problem with the display being left on for many years, I have seen only one person on the community that has had display issues that I can remember since the 6600M came out.
I myself really wish there was a switch to turn OFF the display as I also 90% of the time run remote and don't need a very expensive night light.
It would be nice to have the screen saver time out after even a hour of none use would be much better then leaving it on all the time.
just my 2 cents.
73's
Bret
WX7Y
A way to turn the display off or a screen saver would be nice yes. But leaving the display on all the time does not cause a problem and won't harm anything.1
Thanks. I'll not worry about it too much then.
Sometime when I remotely turn it on, it powers up with the startup screen and at other times it powers on to a previous waterfall and slice.
I wish it would come up every time with the startup screen to simplify things.
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
