Stream Deck and Digital Loggers Switch
John - K3MA
Many members of the community use the Digital Loggers Web Power Switch to control remotely many items in the shack. I have seen it used for controlling PC and Flex Radio power supplies and also the Remote on/off function in SmartSDR.
I believe now the control of this Web Power Switch (maybe others) can be programmed as buttons on the Stream Deck device that some are using with FRStack3.
I have not had time yet to setup the Stream Deck to control my Web Switch but here is the REST command reference document for those that might want to add this to the Stream Deck profiles and functionality.
John K3MA
https://www.digital-loggers.com/rest.html
John K3MA
That’s great info John. I use two 8 way Digital-Loggers Switches at my remote site and would be very interested to hear how this works out for you. 73 Winston VK7WH0
I have Stream Deck controlling my Sonoff switches via Home Assistant. Home Assistant has a plug-in for Stream Deck via its webhook api.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
