Stream Deck and Digital Loggers Switch
John - K3MA
John - K3MA Member ✭✭
edited August 2019 in New Ideas
Many members of the community use the Digital Loggers Web Power Switch to control remotely many items in the shack.  I have seen it used for controlling PC and Flex Radio power supplies and also the Remote on/off function in SmartSDR.
I believe now the control of this Web Power Switch (maybe others) can be programmed as buttons on the Stream Deck device that some are using with FRStack3.
I have not had time yet to setup the Stream Deck to control my Web Switch but here is the REST command reference document for those that might want to add this to the Stream Deck profiles and functionality.
John K3MA
https://www.digital-loggers.com/rest.html
1 votes
In Review · Last Updated
  • VK7WH Winston
    VK7WH Winston Member ✭✭✭
    edited August 2019
    That’s great info John. I use two 8 way Digital-Loggers Switches at my remote site and would be very interested to hear how this works out for you. 73 Winston VK7WH
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    edited August 2019
    I have Stream Deck controlling my Sonoff switches via Home Assistant. Home Assistant has a plug-in for Stream Deck via its webhook api.
