Joe Taylor K1JT hints at next generation of digital modes
edited January 2020 in Third-Party Software
This was taken from an excellent blog by EI7GL.
It would be interesting to hear how; if at all,l it will impact Flex users.
And importantly, how will it be interpreted by potential Flex customers like me.
I do not fully understand  flex architecture.
Would be great to hear this discussed....
"In a recent short talk at the amateur radio show in Friedrichshafen, Germany, Joe Taylor K1JT gave a hint of a new digital mode in the pipeline.
This will use the I and Q output of a SDR transceiver for receiving and sending the signals and over a wider bandwidth. This will be a major departure for the current suite as it will not be compatible with superhet transceivers."
Stu
2E0XXO
Welcome!
  • Member ✭✭
    edited August 2019
    Sounds interesting. I'll have to find that Blog. It also sounds like it'll be a very wide mode which may be the reason legacy transceivers can not handle it.
  • Member ✭✭
    edited August 2019
    Well this is something I am keen to learn about! Fascinating trend.
  • Member ✭✭
    edited August 2019
    here the blog and the video is there too.
    interesting times ...
    https://ei7gl.blogspot.com/
  • Member ✭✭
    edited August 2019
    It's the I and Q portions that will give them trouble.
  • Member ✭✭✭
    edited January 2020
    Interesting. Well, of course it's quite possible to use broad bandwidth with analog methods. It's just easier and cheaper to make radios with SDR technology now. I and Q outputs, whether analog or digital, are needed if you want to preserve phase information. E.g. separating positive and negative IF frequencies. Fortunately, Flex gives us I/Q through DAX so we're well set for wideband WWSJT or whatever. (On receive but not transmit) What's not so clear is whether there would be FCC support for >3 kHz WB modes on any bands below 450 MHz - unless you're an AM or ESSB op. :) 73 Martin AA6E
  • Member ✭✭
    edited October 2019
    We are so lucky to have someone with Joe's experience and passion as a member of the Amateur Radio community. I can't wait to see what he and his team come up with for us next.
    What a great time to be a ham.
  • Member ✭✭
    edited August 2019
    One of the huge developments in Amateur radio over the last few years have the development of digital modes like FT8. The software (WSJT-X) for these modes uses the sound card in a PC to decode and encode these digital signals.
    Up to now, this approach allows it to be used with standard superhet transceivers.
    By John, EI7GL https://ei7gl.blogspot.com/
  • Member ✭✭
    edited October 2019
    has anyone heard anymore of this new mode ?
  • Member
    edited October 2019
    Both the CW and RTTY skimmer servers use the IQ data, not the audio stream. So the concept by itself is no new.
  • Member ✭✭
    edited October 2019
    ok thats great, but any news of the actual mode/bandwidth itself ?
