Strange Antenna Port Issue with 6700, Version 3.0.27
Tom OBoyle
I have owned by 6700 for years and all is usually working well. This week, I've experienced a problem. On startup, I noticed no signals on REC. I checked antennas and all seems OK. I transmit and SWR is at 1.2 or better. My REC and TX antennas are always on ANT1. Now, if I change the TX antenna to ANT2 -- signals are received correctly. I have checked out the antenna settings and the gain and all are still set to the correct settings.
I did switch bands many times and I got the radio to work normally. Then a few days later it happened again and this time I cannot get it to work right. I've rebooted many times and factory reset
Any ideas? It is almost like there is a circuit kicked in to reduce the gain when on ANT1 for TX.
73 de Tom, N9GUN
73 de Tom, N9GUN
Tom,
I recently had a problem where ANT1 would not receive or transmit. ANT2 was ok.
Turned out to be a bad relay on ANT1. Factory repair required.
I suggest you put in a ticket to the help desk.
Roy - W5TKZ0 -
Recently had a similar issue. Like Roy, arranged an RMA with Flex. Relay replaced and radio back better than ever after a short spell in the FRS Clinic.0
Tom,
Look at your email.
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 451 Remote Operation (SmartLink)
- 996 Third-Party Software
