Strange Antenna Port Issue with 6700, Version 3.0.27
Tom OBoyle
Tom OBoyle Member ✭✭
edited December 2019 in FLEX-6000 Signature Series
I have owned by 6700 for years and all is usually working well.  This week, I've experienced a problem.  On startup, I noticed no signals on REC.  I checked antennas and all seems OK.  I transmit and SWR is at 1.2 or better.  My REC and TX antennas are always on ANT1.  Now, if I change the TX antenna to ANT2 -- signals are received correctly.  I have checked out the antenna settings and the gain and all are still set to the correct settings.
I did switch bands many times and I got the radio to work normally.  Then a few days later it happened again and this time I cannot get it to work right.  I've rebooted many times and factory reset
Any ideas?  It is almost like there is a circuit kicked in to reduce the gain when on ANT1 for TX.
73 de Tom, N9GUN
  • RoyS
    RoyS Member ✭✭
    Tom,
    I recently had a problem where ANT1 would not receive or transmit. ANT2 was ok.
    Turned out to be a bad relay on ANT1. Factory repair required.
    I suggest you put in a ticket to the help desk.
    Roy - W5TKZ
  • Tom OBoyle
    edited August 2019
    Thanks..   here is a short screen video showing the issue.
    https://youtu.be/iqaDHonlXcU
  • George KF2T
    George KF2T Member ✭✭✭
    edited August 2019
    Recently had a similar issue. Like Roy, arranged an RMA with Flex. Relay replaced and radio back better than ever after a short spell in the FRS Clinic.
  • RT5A
    RT5A Member ✭✭
    edited August 2019
    Tom,
    Look at your email.
