MOX lights up when I talk
Ok but green arrow update not loading when I press It goes through one step than last step says no internet. Connection0
Joe I think you are solidly in Help Ticket territory unfortunately.
Another option is if you can get the brief connectivity to the Internet to get by that point, but again I'd reach out to FRS to make sure your efforts count.
GL and 73
Steve
K9ZW0 -
It loaded 3.0.1.9 now this up again
Now I need find were VOX setting at 0 -
Worked have this screen up now after pressing speed/power button loos like VOX. Off not high lighted
Need find were monitor setting out now as hear myself in headset could just be RFI
MOX still lights when transmit ing but mic not sticking now in transmit
MON was ON —/I shut off now no voice in headset now
Dam I feel dumb
Thanks all very much I clicked on RCA 1 connect to late dads Ten Tec Titan 425 she power girl dad had 12 brand new 800 tubes saved she runs on two 800 tube 12 tunes should last my life time0 -
So Joe, What was the issue, was your Vox on? Is your problem solved. If so how did you fix it.. Thanks,,,,0
VOX is off My voice coming in headset- the Monitor Button was on -Turned off Monitor MOX still lights when talking on ssb but RFI maybe Bob Brehm, AK6R from Palomar looking into it now Sent me link link: https://my.ecwid.com/store/10325621#product:mode=edit&id=86891138&return=products:name-or-sku=flex&count=2147483647 Mic not going in VOX now so far keeping fingers crossed after I uploaded new V.3.0.1.9 I did get this wonderful DSP remover for Ten Tec Omni 7 Might try on 6400M but DSP so far removed noise better than my sold icom 7610 and icom 77000
Hi Joe Glad you are making progress. It is normal for MOX to light while pressing the PTT. It should go off once you release PTT. I think the problem you had when the radio stuck in transmit was due to downgrading software to 2.4.9. If you downgrade to 2.4.9 or lower you must factory reset radio to default settings and then load a stored profile (if you have any backed up) using a PC and SmartSDR for PC. Upgrading back to 3.0.19 seems to have fixed the stuck PTT. The PC connection is optional and I think you mentioned you want to buy one once you have Internet. The PC will allow you to do electronic logbook, digital software such as WSJT-X and other programs. Enjoy using the radio. They really are fun! 73 Dave wo2x0
It is normal for MOX to light while pressing the PTT. It should go off once you release PTT. Thank u Dave Joe Ok glad for everyone’s help I’ll talk on Triple H net tonight 7190 11pm AK till around 1230am see if everything ok- anyone cannot sleep give me call KL4QG I’m in Bethel AK training new oper at water drinking system0
Flex Help desk told what problem was like I said MON was on I did no it and delay was on high cause my problems with mic saying on too0
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
